5.3 will not idle
Old 06-29-2006 | 08:58 PM
samcolt's Avatar
Thank you for the tip, but what will this tell me or do?
Old 06-29-2006 | 09:18 PM
CNE's Avatar
CNE
Is this truck an electronic throttle body or cable driven? Probably cable since it's a 2000. If it's electronic, it may be the throttle body itself, at the dealer we have replaced several of them for stalling concerns. If it's cable, there is a procedure we can do at the dealer where we install a small plug in the orifice in the throttle blade, then adjust the throttle plate open slightly to prevent future sticking concerns. You must install the fixed orifice pcv valve if you do this though.
Old 06-29-2006 | 09:28 PM
samcolt's Avatar
This is cable driven. When I took it to the dealer, they couldn't duplicate the problem. They cleaned the throttle body, and it did it again the next morning.
Old 06-29-2006 | 09:35 PM
v8
17,16,15,14,13,12,11 Drvr
if you do what I mentioned it will help the computer learn your idle again.
Old 06-29-2006 | 09:52 PM
samcolt's Avatar
Thank you, sounds worth a try.
Old 06-30-2006 | 09:17 AM
shandy294's Avatar
Samcolt is the truck owner
Thanks again for those who have given advice. Any other possibilities?
7/2: He bought some TB cleaner at O'Reilly and will clean the IAC. BTW,the maint. manual says be very careful what you use and how you clean the pintle,etc. and not to immerse things. I guess carb/choke cleaner is bad.
Old 07-03-2006 | 12:13 PM
shandy294's Avatar
Bumping this mo fo. See entry directly above this one.
Mossyoakglock
08-28-2015 12:49 PM
superchomper2003
08-26-2015 09:39 AM
smokeshow
08-23-2015 08:23 PM
darnie
08-10-2015 10:25 AM
05GMC4.8
08-07-2015 09:55 PM
Quick Reply: 5.3 will not idle
