5.3L Cam Swap Question
A buddy offered to give me a Comp Cam he had laying around. I think it could be to much duration for my 5.3L but wanted to ask the professionals on here if they thought it could work. I also need to know what else I need to make the cam work if possible. Thanks for any help y'all could give me.
Comp Cam #'s: INT. / EXH.
Valve Lift: .600 / .600
Dur @ .050: 252 / 252
Adv Dur: 314 / 314
LOB Sep: 110
Adv Dur: 314 / 314
LOB Sep: 110
K, I figured that. Thanks for the help guys! Which cam out of those do you recommend if im looking to add a little HP's more then stock? I would like to use as many stock parts as possible. Its my daily driver also.
Out of a 212/218, 212/222, 216/224, 220/220 or an LS6 cam assembly which would be the best for a daily driver? Also, would it be a good idea to go with a LS2 timing chain as well?
