5.3L conrod dimensions needed.
#21
Originally Posted by ktmrider
Yes, the zig-zag. Using the fracture joint technique makes for a much stronger clamping structure. Just make sure you number the rod/cap assy as you cannot mix and match!
Final measurements reaserch says:
Big end = 2.10"
small end = 0.927"
End center to end center = 6.098"
Take some pics when done!
Big end = 2.10"
small end = 0.927"
That's what sells machines! I will post up pics when done with my first couple of parts.
#22
length 6.098
wrist pin .945 ( the sbc rods that people are using 6.125, use the .927 pin thus why there are pistons made for them)
bearing id 2.100
bearing od 2.225 (roughly with calipers here in the shop)
bearing id 2.100
#23
Originally Posted by mjhoward
length 6.098
bearing id 2.100
bearing id 2.100
How thick are the walls on either bearing end?
Just looking to see how much meat you need to keep them from flying apart in the engine.
Thanks.
2002_Z28_Six_Speed
10-04-2015 01:34 PM
jscherbs
09-30-2015 07:54 AM
