5.3L conrod dimensions needed.
Old 04-06-2006, 02:01 PM
  #21
TG02Z71's Avatar
Originally Posted by ktmrider
Yes, the zig-zag. Using the fracture joint technique makes for a much stronger clamping structure. Just make sure you number the rod/cap assy as you cannot mix and match!
Final measurements reaserch says:
Big end = 2.10"
small end = 0.927"
End center to end center = 6.098"
Take some pics when done!
The zig-zag will have to wait. I just want to make a non-working part first for show and tell demos here at work. Its more to show machine cutting capability, accuracy, and finsh making capability.
That's what sells machines! I will post up pics when done with my first couple of parts.
Old 04-06-2006, 02:26 PM
  #22
TurboGibbs's Avatar
length 6.098
wrist pin .945 ( the sbc rods that people are using 6.125, use the .927 pin thus why there are pistons made for them)
bearing id 2.100
bearing od 2.225 (roughly with calipers here in the shop)
Old 04-07-2006, 06:26 AM
  #23
TG02Z71's Avatar
Originally Posted by mjhoward
length 6.098
bearing id 2.100
Thanks for the real world dimensions.
How thick are the walls on either bearing end?
Just looking to see how much meat you need to keep them from flying apart in the engine.
Thanks.
Old 04-07-2006, 02:51 PM
  #24
TurboGibbs's Avatar
The thickness of the lower cap in center is .250 and the lower and upper ends are .943 wide. You really need a rod to pattern after.
1_fastsilverado
10-11-2015 11:34 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
redbird555
09-30-2015 09:28 AM
jscherbs
09-30-2015 07:54 AM
old motorhead
09-29-2015 08:22 PM
Quick Reply: 5.3L conrod dimensions needed.
