5.3L getting bad gas mileage??
Old 07-18-2007 | 05:46 PM
ZZebes's Avatar
so around 350 miles per tank. thats actually better than i get i average 200-250 miles per tank
Old 07-18-2007 | 06:29 PM
2001si3rr@'s Avatar
If you are getting around 350 miles per tank that don't sound too bad. I get just a bit more than that daily driving my 2000 5.3 ECSB Silvy, only mod is a K&N CAI.
If you had a issue with cats, O2's, or something related you should get an engine code letting you know there is a problem.
How many miles on your current spark plugs and wires? When was your last oil and oil filter change? Have you tried the Sea Foam treatments?
Old 07-18-2007 | 09:39 PM
coryhussey's Avatar
its an 03 with 73000 Kms, so its like 40,000 miles or so. It may be time for a tune up as well. I bought it from a dealer last november. Not too sure if they did their usual gm tuneup or not. Might try plugs and wires for now. And maybe look into the computer diagnostic if not. elaborate on the sea foam, I have not heard too much about it. thanks
Old 07-18-2007 | 09:44 PM
nightrunner's Avatar
Mr. Obvious
i bet its the MAF needs cleaning from an overoiled filter
you arent getting "bad" mileage maybe not as good as you used to but still not bad for a truck
Old 07-19-2007 | 08:21 AM
2001si3rr@'s Avatar
Yeah, your mileage in not bad. I bet the dealership didn't do any kind kind of tune up before you bought the truck.
For the Sea Foam check this out: https://ls1tech.com/forums/showthread.php?t=534376
Hope this helps.
Corvette454l88
09-01-2016 02:24 AM
RedDeadG8
26
12-01-2015 12:32 PM
FlowmasterMufflers
08-14-2015 01:47 PM
05GMC4.8
08-07-2015 10:55 PM
FlowmasterMufflers
07-17-2015 04:26 PM
