5.3L heads and block info?
Old 10-28-2009 | 11:49 AM
04gibbstahoe's Avatar
Default 5.3L heads and block info?
I am fixing to have a custom cam ground for my setup, and the cam vendor needs some information that I do not have about my vortec 5.3L. I need intake and exhaust valve sizes. Bore and stroke. Connecting rod length. And any other information that might be useful in trying to spec out a came. Thanks.
Old 10-28-2009 | 09:29 PM
06WT's Avatar
1.90 1.55 valves, 96.01 mm bore and 92.00 mm stroke, as for rod length im pretty sure its the same rods as an ls1, so just do a search for ls1 rods
Old 10-28-2009 | 09:47 PM
06WT's Avatar
center to center rod measurement 6.125''
Old 10-28-2009 | 09:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
what cam vendor doesn't know? Makes me a little nervous
Old 10-28-2009 | 10:02 PM
SweetS10V8's Avatar
No doubt, its a 5.3L. Whats to ask? Stock rods are 6.098" IIRC, 6.125" are aftermarket.
Old 10-28-2009 | 10:04 PM
06WT's Avatar
i was thinkin that too, but mayb hes getting it through a shop thats not into lsx and late model stuff, but then again whats a shop that dosnt deal with lsx doing grinding a cam for one. none the less he has the info now
Old 10-28-2009 | 10:10 PM
06WT's Avatar
well there you go, i knew some one would have it. i just looked in the jegs book and saw 6.125'' so that would explain sweets10s post
Denali08
08-09-2015 04:34 PM
gtyler04
07-28-2015 06:21 PM
Cowboy Tom
07-21-2015 10:29 PM
Offroadunleashed
07-20-2015 02:25 PM
jmarkway
07-18-2015 09:23 PM
Quick Reply: 5.3L heads and block info?
