5.3L, needs 12.5:1 - 13:1 compression.
Trying to make a project 5.3L run on straight alchohol, anyone know if they make pistons to meet my compression needs? I can mil the heads and run a thinner gasket if needed. Any help at all is appreciated!
Isn't the alcohol best kept chilled in a bottle in your hand?
Anywho, research into replacement 4.8L pistons if you're wanting to keep the 96mm bore (I would personally so it can take the abuse) because I read somewhere on here that 4.8L pistons are flat tops compared to 5.3L pistons. I have no specifics, but it's a direction you can check into.
If those do work, flat tops in a 61.15 cc chamber will already send ya into the 11+ compression range. Milling then becomes cheaper because you'll have less to take off, also while making sure you've gone through the motor for a complete rebuild before pounding it with alcohol.
Question...would a motor run on alcohol be required to attend AA meetings?
Stock flattops from an L33 with 862s cut to 56ccs will get you over 11.5:1 with a thinner gasket.
Can't go much higher on a 5.3 easily.
cutting more runs into intake fitment problems, and valves start to get pretty close to pistons, etc
I suppose you could weld the chambers...
What is the engine for?
zblee
11-11-2015 12:41 AM
lxcoupe
10-04-2015 08:07 PM
