5.3l pistons in a 4.8l?
Old 01-10-2009, 03:23 PM
SynergyV8's Avatar
Originally Posted by TyDreams
If i could run the 6.0 heads to lower compression to 8-8:5 i could turn the boost up a bit.
You're looking at 8.3:1 with 6.0L heads. This isn't the 1970's, technology has come a long way. Crank up the boost with higher compression, just be sure of your tune, gas quality and thermal management. Let the intercooler do it's job.
Old 01-10-2009, 07:33 PM
kbracing96's Avatar
What size turbo were you running to get that?
What was the redline at and dose it have the same redline as the 5.3.
I know that the 5.3 would put out a few more ponies but i can get a 4.8l for $200 and the 6.0 head run $200-300. So for $500 it wouldn't cost me to much. If i could run the 6.0 heads to lower compression to 8-8:5 i could turn the boost up a bit.
I was running a Master Power T70 with a .68 A/R
This was just at a dyno day a GTO club was having that I happened to be invited to. I only made 3 pulls. With a little more tuning, could have been better
Old 01-10-2009, 07:57 PM
TyDreams's Avatar
Those are good numbers and exactly what i'm looking for. Now all i have to do is off load this vette to make room.
lukn4trbl355
10-21-2015 11:19 PM
turbo6c3
10-05-2015 06:11 PM
trevorh1
09-27-2015 08:47 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: 5.3l pistons in a 4.8l?
