5.3L Tahoe hard to crank
Old 12-09-2013, 08:33 AM
  #41
hog
hog's Avatar
Originally Posted by 99corvette
Update: rented a fuel pressure checker again. Key turned over just primed and not running got 50psi. Then running got 45psi. Then running with fuel pressure regulator unplugged got 55psi. Sound normal?
Not running and running without vacuum refernce should be the same assuming good state of battery. The only one that should be lower is running with vacuum reference attached.
peace
Hog
Old 12-09-2013, 08:51 AM
  #42
10 Second Club
99corvette's Avatar
I didn't prime it with the regulator unplugged.
Old 12-13-2013, 09:09 AM
  #43
10 Second Club
99corvette's Avatar
Well put a coolant temp sensor on and that did not fix the issue, I have a MAF on the way that I am gonna try next.
Old 12-19-2013, 06:52 PM
  #44
10 Second Club
99corvette's Avatar
Tried another MAF and that did not help. Im about to break down and take it to GM to have them diagnose it i guess.
Old 12-20-2013, 09:24 AM
  #45
GMC93's Avatar
45psi at idle is too low right? Is the new pump an oem pump and did you replace the whole assembly or just the fuel pump?
Old 12-20-2013, 11:24 AM
  #46
10 Second Club
99corvette's Avatar
That seemed low to me also. Some people are telling me it is but some are saying for a flex fuel it's ok...? I replaced the whole pump assembly and not just the pump. I bought a good brand pump.
Old 01-01-2014, 09:36 AM
  #47
GMC93's Avatar
Sounds like a weak pump with a faulty check valve thats backflowing into the tank versus keeping the system pressurized. If its nee return it for a new one
Old 01-01-2014, 09:43 AM
  #48
10 Second Club
99corvette's Avatar
Well that's what I thought too so I put a new pump in. No difference. I also let it sit over night and checked the fuel pressure with just turned over once and it had instant pressure. You can prime it 10 times if you want but it won't crank unless the gas petal is held down.
SLOPONY
20
10-18-2016 06:05 AM
chevyl33
08-24-2015 08:21 AM
mz00516
08-23-2015 12:19 PM
InsaneDomestics
07-27-2015 02:42 PM
Quick Reply: 5.3L Tahoe hard to crank
