5.3L- What can they do?
Old 12-05-2005, 02:42 PM
  #31
quicksilverado's Avatar
Originally Posted by ZRO26T
Turbo'd V8, A4 & 3.02s? I'd really look to shrinkin' those gears to at least 3.73s. With a 4L60E (hypothetically speaking) and 3.73s, your RPMs @ 70 mph would be around 2100. Anyone disagree? My GM's RPMs @ 70 mph (w/ 3.42s) are roughly 1800 (w/ the 4L60E).
3.02 will be fine with a v8 and turbo.
Old 12-05-2005, 03:46 PM
  #32
is a 6.0- just a stroked 5.7L? what do they make for hp/trq? and can they handle some boost in stock form?- Also do they use a 4l80e?
Old 12-05-2005, 05:39 PM
  #33
formerly 1BADC10 (12/14/2011)
95ImpSS's Avatar
Sure, he can run 3.02s w/ what he's looking to upgrade to. Just hard to fathom that someone, who's goal is to put down 500rwhp, wouldn't want to skate his vehicle down the 1/4 mile as quick as possible. That's like me build a 12s truck, and keeping my 2.73s.
Why not maximize your potential? Why not make it easier to move the weight? Might as well be .
Old 12-05-2005, 06:35 PM
  #34
its for gas mileage reasons...... And again would a 6.0 fit 5.7L motor mounts? Do they use a 4L80E-
DO 6.0L HANDLE BOOST WELL AND CAN THEY HANDLE 500+ hp easily on stock bottom end?
Old 12-05-2005, 07:32 PM
  #35
F8L Z71's Avatar
Do you understand that turbos don't like low gears? They are much different than blower or N/A cars. Maybe you should be asking what size tire he plans on running
Old 12-05-2005, 09:19 PM
  #36
95ImpSS's Avatar
I remember what he said about boost. Thinking if he's got something that weighs 3700lbs, even a 5.3 w/ the right bolt-ons can put him in the 12s w/o boost. Now, given his response here...
... I can see his reason behind taller gears. If he's dead set on boost, taller gears would suit best. Just putting other options out there. I like to present different angles, and let people make choices that they see best. That's what I wanted when I was shopping for the right swap. If low 12s are the best he expects, then he'll be grinnin' cuz a 6.0 w/ boost (built right) should get him there and quicker. Litreddevil & I are expecting low 12s outta the 5.3 I'm mounting soon. I spent way less than what I expected for what I'm getting.
Originally Posted by litreddevil
I don't know your budget... i know u can get alot of a 5.3.i went 12.59 with a stock motor with a cam,no head work. flyer ran 11.9 something with a 5.3 and a s/c.that is respectable to me they have some on here that has put the lsx to the test and still possibly get more. i am going to get ZR026's truck in the lower 12.s after the tune.
so it is realy a money thing what do u want to spend and how fast do u want to go.
Again... I'm just putting other options out there. Seems like 02Vortech's still in the research phase.
Old 12-05-2005, 09:52 PM
  #37
F8L Z71's Avatar
I hear ya
Old 12-06-2005, 06:07 PM
  #38
yeah research research research- Where can i find good 6.0's for like $1500 and less? Can i find them (ECU / wiring harness/ complete oilpan to intake manifold....?) Do they run a 4l80e?- Once again CAN THEY HANDLE 10 to 15 PSI PRETTY WELL? or do i need to get better fuel system?
Old 12-06-2005, 06:40 PM
  #39
CrabhartLS1's Avatar
If you've got a high stall, and a powerful drivetrain, there's nothing wrong with tall gears. That just means you'll hook up better.
For example, an A4 LS1 with a 3000 stall will beat an M6 LS1, all other things being equal. Don't be afraid to go with 3.09s or even 2.73s, there are plenty of 2.73 people doing 12s and high 11s out there.
Old 12-06-2005, 06:44 PM
  #40
F8L Z71's Avatar
As long as it's not a freeway race
Quick Reply: 5.3L- What can they do?
