5.3Questions????
Old 07-08-2002, 02:13 PM
Default Re: 5.3Questions????
Excellent reply...Mixon nice and to the point...lol its all about cubic dollars <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old 07-08-2002, 02:42 PM
GREGGO's Avatar
Your preaching to the choir about breaking things. Yes things do just go bad. This was on 100 shot. # 5 bit the dust on a 14.6 run.
<img src="http://home.swbell.net/greghud/piston.jpg" alt=" - " />
<small>[ July 08, 2002, 02:43 PM: Message edited by: Fast4.8 ]</small>
Old 07-08-2002, 02:47 PM
Are you saying nitrous did that? That is the only motor i've seen that has been sprayed and the pistons were not shiny. How come there is carbon all over the piston? Did you drive it after this pass for a while with a bad miss?
________
New Mexico Marijuana Dispensary
Old 07-08-2002, 03:18 PM
Moderator / Sponsor
oxidizr's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I was kicking around the idea of building a nice 5.3 and putting it in something.Can you big HP guys give me some advice and info on the 5.3?Does anyone run ported heads LS1/LS6 good cam?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a set of stage II+ LS6 heads and a 230/235 .595/.595 114 cam going into my 6.0L build. I should have results of this in the next two months.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I'm thinking some of the juice may be in order.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nothing wrong with that...you can support typical EFI nitrous levels around 150 HP.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">What should I look into when building the internals?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I went with some custom .003 over forged flat top pistons which I sent to HPC for thermal and oiling coatings. I have 6.125" H beam rods runing a 2.000" journal with a bearing spacer to accomodate the offset grind of the 6.2L crank. I though about billet caps but I think the 6 bolt pattern and steels should hold fine.
The motor is a good base for a bolt-on or FI small CI project but if a stroker or big HP is your desire start with the 6.0L block.
Richard
Old 07-08-2002, 04:25 PM
NICE PICTURE!! IF YOU WOULD HAVE USED A 150 SHOT YOU WOULD HAVE DONE BETTER THAN 14.6,AND HAD MORE FUN BLOWIN IT UP...LOL IT'S ALL IN FUN THOUGH!!! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" />
Old 07-08-2002, 06:36 PM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by hyde:
<strong>Are you saying nitrous did that? That is the only motor i've seen that has been sprayed and the pistons were not shiny. How come there is carbon all over the piston? Did you drive it after this pass for a while with a bad miss?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Drove it for 3 weeks. It still ran fine (to a degree) but sounded bad and I knew I was gonna have to have the whole thing replaced anyway. And no I never sprayed that, that was a typo. <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old 07-09-2002, 12:22 AM
blackLS1's Avatar
Thanks guys.I know I'll learn alot on this forum.I have already learned alot about LS1's from the internal engine section. <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old 07-10-2002, 03:51 AM
blackLS1's Avatar
Thanks oxidizr,I want to build a small cubic inch motor.I like the idea of building a modern day 327.I know it doesn't rev like the old venerable power plant but I still like it.
Since these are similar to the LS1 do they have the same weak points?Weak rod bolts and such?
Does any have a pic of the intake manifold or motor pic with out the cover over the intake?How high does it sit up? <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 07-10-2002, 07:14 AM
The rods and bolts and pistons are the weak spot here, on the truck motors
________
TINY **** LIVE
Old 07-10-2002, 09:02 AM
Moderator / Sponsor
oxidizr's Avatar
This isn't a full picture of the manifold (but its the only one I have) and it got a bunch of "extra stuff" on it butyou can see how its is about 5 1/2 inches taller than the LS1/6 style manifolds.
<img src="http://home.earthlink.net/~rwaitas/_uimages/directport3.jpg" alt=" - " />
Richard
