.551 lift on LS6 springs?
Old 06-22-2008, 03:41 PM
  #21
InchUp's Avatar
This is where I bought mine.
http://www.lingenfelter.com/store/12499224.html
Old 06-22-2008, 04:37 PM
  #22
all you need is the springs, everything else can be reused with no problems. I bought mine from the dealer for $45+tax...
Old 06-22-2008, 05:17 PM
  #23
richierich14608's Avatar
Are LS6 blue and yellow the same or different?
Old 06-22-2008, 05:40 PM
  #24
12 Second Club
AdioSS's Avatar
ideally with a hydraulic roller cam you want your closed pressure to be 120-200 and your open pressure to be 300-400.
Old 06-22-2008, 08:10 PM
  #25
PT's Slowest Truck
budhayes3's Avatar
As far as I know, the blue springs are rated at less lift than the yellow ones...
Old 06-25-2008, 12:57 PM
  #26
leochevy2001's Avatar
from what i have read on tech, the blues one are rated at .550 and the yellow are rated at .570-.580.
Old 06-25-2008, 01:20 PM
  #27
Originally Posted by southern_chevy
Ya I like the piece of mind that they are factory parts that are made to last the life of the car. I have not had any problems with them just would like to compare the springs spected for a cam vs the ls6 ones. Anyone know where I could get this kind of info for my MTI T1 cam?
i have a mti t1 cam and it is a lunati grind.
looked at the lunati catalog and couldn't find the info that you asked for but i found the springs that they recommend for the cam.
here are the spring specs:
75818LUN Enhanced LS1 Ovate Beehive Valve Spring .600" Lift
OD 1.290"/1.055"
ID .885"/.650"
Seat Load 130@1.800"
Open Load 318@1.200"
Coil Bind 1.140"
Rate (lbs/in) 313
Old 07-01-2008, 06:21 PM
  #28
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
PAC is neither Patriot or PRC. PRC is Precision Race Components, sort of the manufacturing and machining division of TSP if you will. PAC makes our springs, they are a great company with a great product.
Old 07-01-2008, 09:33 PM
  #29
southern_chevy's Avatar
Leo that sure is a lot more pressure then the ls6 will come close to but I have had no problems so far with them. I guess they are still treating you good as well?
gaps
10-15-2015 02:53 PM
jtphelps289
09-29-2015 12:00 PM
LARRY01Z28
08-01-2015 10:15 PM
Offroadunleashed
07-20-2015 02:25 PM
07NBSChevy
20
07-08-2015 07:27 PM
Quick Reply: .551 lift on LS6 springs?
