5v source
I have a gm map sensor and gm oil/fuel pressure sensor that I have installed for the boost and fuel pressure, but I'm not sure which wire I can get 5v off to power them. I suppose I can just take a multimeter and start testsing away but I figured I would check here before I did that
When I Installed My Fuel Pressure Sensor I Spliced 5v And Ground From My Map Sensor On The Top Of The Intake Cause It Was The Closest. Give Me Your Vehicle Info And I Can Get You Wirecolors.
I don't think I have egr.. there is nothing comming the exhaust manifolds? Do you mean there could still be wiring there? Got any idea what wire colors or where to look?
