6.0 and 4l60e ??? have to ask
Old 08-16-2005, 12:36 PM
TURBHOE's Avatar
Default 6.0 and 4l60e ??? have to ask
can i bolt a 6.0 to my 4l60e with my 4.8 torque converter and fly wheel. i know it will explode but this is for temp use until i can get my 4l80e
Old 08-16-2005, 12:54 PM
rosscob's Avatar
Yep bolt it all together.
Old 08-16-2005, 01:03 PM
TURBHOE's Avatar
ok because what i'm trying to figure out is why you have to have a crank spacer for the 4l80e to bolt to a 4.8 but can bolt a 6.0 to a 4l60e
Old 08-16-2005, 01:13 PM
Check out Automotice Rebuilder, they seem to explain the difference between 4.8, 5.3, 5.7, 6.0 pretty good.
Old 08-16-2005, 02:12 PM
rosscob's Avatar
When I did my swap I seem to recall that if the 6.0 was older than 02 I would have to use a crank spacer, but since it was out of an 04 I didn't have to.
Old 08-16-2005, 02:23 PM
TURBHOE's Avatar
so being this is a 03 then i should be good
Old 08-16-2005, 02:33 PM
jerome's Avatar
it would do much better for you to pull the 60 and sell it instead of using it temp, which would probably break it. hold out until the 80 if you can?
Old 08-16-2005, 05:02 PM
gonzo 6.2's Avatar
Leave out the spacer,use your 4.8 flexplate and bolts.Do a vette servo and a shift kit and you will be fine for a long time unless your the kind of guy that can destroy an anvil.Guys running 12s can make a 4L60 live with a shift kit and a servo.
Q:42Lb injectors are not really needed on a N/A are they?
Old 08-16-2005, 05:54 PM
TURBHOE's Avatar
A: nope but the big turbo they will be. and when i done my head swap i figured why not put them in so i don't have to later.
Old 08-16-2005, 08:29 PM
So your getting the 6.0?
Quick Reply: 6.0 and 4l60e ??? have to ask
