6.0
Old 05-23-2007, 10:35 PM
  #31
Tootall's Avatar
Originally Posted by ramsey rider
i took your advice from everyone here and bought a 6.0 w/400 miles on it today for 1500.00 top to bottom w/all acc.
that's pretty cool, that's a great deal for the miles, where did you get it?
will i have any problems bolting it up to my 1500 sierra and will there be any wiring harness issues or computer problems
bolting it up?- not a freaking one, but you will need a custom tune. You can either get a live tune around you, or get a mail oder tune from one of the sponsors, or pm "wheatley" Either way, one of those guys can help you.
Wiring harness - it's the same one, you will not have any problems. Be sure you plug everything back up. EVERYTHING goes back the way that it was.
like do i need the comp out of the vehicle the motor came out of.
No,- This is where the custom tune comes in. It gets programed for your engine and transmission.
Yes if you want an extra computer (PCM), but there's no need for it.
i know theres tons of post about swaps but this is a van.
It doesn't matter, it's still a 6.0 and its an `06. There are no issues with putting it in. Search my name, I did the same swap, I asked a TON of questions, and took all kinds of pictures.
oh will my 4l65e bolt up ok what do ineed to do to make it work long stort short.
bolting up? yes no problems at all, it'll be as if it was supposed to have been there in the first place. I will suggest a hotter cam. The stock one will work, but believe me, your going to want to go bigger. I did a mild cam, and I wish that I would have gone bigger.
Transmission work better? a shift kit will make a world of a difference. Do a search for "Transgo HD2" It's a true reprogrammer for your trans, and it helps with the life of it.
Summary - all that you're changing is the block and heads, nothing else, everything else is reused again.
Old 05-23-2007, 10:42 PM
  #32
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Originally Posted by RandomHero
that ****** weighs 9000lbs? Holy crap
GVWR= gross vehicle weight rating as in thats how much the vehicle weighs loaded to full capacity.
Like our trucks GVWR is 7000(for instance my truck weighs 5200 unloaded just for figuring purposes) so it can carry 1800#s in addition to the vehicles weight.
Old 05-24-2007, 12:42 AM
  #33
gmforlife's Avatar
Yah where did you get the deal on that motor anyway? I am in search of an lq4 here in about a month, trying to find good places to get the motor with as low a mileage as possilbe.
Old 05-24-2007, 06:39 AM
  #34
ramsey rider's Avatar
thanks for all the answers and help .to answer the question where i got it .at a salvage yard in glens fall n.y. .
Old 05-24-2007, 07:15 AM
  #35
agreif's Avatar
are you sh!tting me, I'm just south of that. Good for you!
Old 05-24-2007, 03:34 PM
  #36
maximumrebel1's Avatar
Originally Posted by nightrunner
the only difference-performance wise between the lq4 and lq9 is a small compression diffrerence ( higher on lq9) and the tune
yes in stock form the lq4 what you have has lower hp than the lq9
My understanding was that the Lq4 was an iron block and the lq9 aluminum.
Old 05-24-2007, 03:47 PM
  #37
Mr. Obvious
nightrunner's Avatar
nope both are iron block
Old 05-24-2007, 05:36 PM
  #38
Tootall's Avatar
and both have aluminum heads.
99's and some 2000 had iron heads
Iron heads have the longer crank, and that's bad unless your going to run an 80e trans
There's lots of pics about this floating around, use the search at the top.
Old 05-24-2007, 06:50 PM
  #39
Tootall's Avatar
im starting mine tomm. will the flywheel off the 6.0 or visa versa work on the 4l65e of mine in my truck ?im doing it over the weekend and i dont want any speed bumps .so everything off the 06 6.0 will fit on my o4 sierra ?if you have any tips for me id appr. them .ive got my 4.8 hyper programmed do i just leave it that way till i get tuned .is it driveable without tune ?its my dd and i dont know how quickly i will get the tune .
again, all you're swapping over is the heads and the block, nothing else.
Get rid of the hypertech, it's crap, and it's useless, ebay it for 10-150, and never pick it up again
1. get a stock 6.0 tune
2. get an engine hoist
and read up some more https://www.performancetrucks.net/fo...earchid=546881
Old 05-24-2007, 08:21 PM
  #40
TarheelZ's Avatar
Originally Posted by gmforlife
...Merchandising Model : CG23406 - 2007 EXPRESS 2500 PASSENGER VAN
This says it's an '07 motor.
Quick Reply: 6.0
