6.0 Build-Need a question answered please.
Hello to all. I have been searching and reading for a little bit to try and figure some things out. I know there is a difference between the lq4 and the lq9. I also understand that the lq4 had a different crank in early 2000 therefore not allowing a T56 to bolt up.
SO HERE IS MY QUESTION- I have a chance to get an early style lq4 and I was wondering if I was to change the crank (forged bottom end setup) WOULD I be able to mate a t56 to this block/crank setup. I am just making sure that since the early 2000ish cranks WERE different, the block would still work if I was to build the bottom end like I was building for an older LQ4. Thank you guys/gals.
Clark
Clark
Now if you're wanting a stroker crank then do that.
If you're looking for some comparisons, there plenty of guys that are running stroked 6.0 (408s) with a t56 behind them on LS1tech
Abuckeye
08-19-2015 06:11 PM
