6.0 Buildup - Your advice wanted.
Old 09-14-2010, 11:25 AM
  #191
blsnelling's Avatar
Any chance that I need to check PTV clearance on this setup? Dished LQ4 pistons, 243 heads milled .035", OEM head gaskets, and .581 lift cam.
Old 09-14-2010, 11:32 AM
  #192
PT's Slowest Truck
budhayes3's Avatar
That's with the 220/224 cam correct? You shouldn't have any problems, guys have run bigger bumpsticks and milled heads on LQ9's without checking all day long
Old 09-14-2010, 11:36 AM
  #193
blsnelling's Avatar
Yes, 220/224 .581/.581.
Old 09-14-2010, 11:49 AM
  #194
Dezert1500's Avatar
Especially with no advance you should be fine. I always check though, but that's me.
Old 09-14-2010, 08:49 PM
  #195
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
How do you like that book you posted a pic of? Ive got a few online links saved for clearances and such but its alwas nice to have some handy reading material on the shelf. Another great but older LSx book is Will Hanzel's Chevy LS1/LS6 V-8s and also Engine Blueprinting by Rick Voegelin. The later is more general but has some good building tips. I like anything that has to do with building motors so it doesnt take much to entertain me
Old 09-14-2010, 08:59 PM
  #196
PT's Slowest Truck
budhayes3's Avatar
I'll let you know how I like it too, as I just ordered it last night after seeing the pic in this thread I'm getting more and more curious as to how your combo's going to run since I'm a long way off from my LQ9 project, and have been going back and forth between cam specs of 224/2xx and 220/224 forever...the past day or two I have been back on the 220/224 kick...(if I had the dough I'd really like a Vinci Stangbanger 220/224 with the Crane 1.8 Gold Race Rockers and Crane dual springs )
Old 09-14-2010, 09:06 PM
  #197
GMCtrk's Avatar
I'm really beginning to wonder if that motor will be in the truck in the next 10 years
Old 09-14-2010, 09:08 PM
  #198
PT's Slowest Truck
budhayes3's Avatar
Me too brother lol...it all comes down to dough, of which I have none
Old 09-14-2010, 09:32 PM
  #199
blsnelling's Avatar
Oh my goodness, are those head bolts tight! 22 ft/lbs + a total of 160°? Wow! Scary I tell you. How those threads don't pull is beyond me. But it's done.
I did coat the GM head gaskets with copper spray just for insurance. I want to do everything I can to ensure a successful build.
I checked the pushrod lengths on all four corner cylinders. They're all 9 - 9 1/4 turns on the adjuster. I don't have a 8" caliper. I'm using a Comp Cams tester. I believe that comes out to 7.25"-7.265".
7.265 + .05 = 7.315
7.250 + .075 = 7.325
Looks like I'll need a set of 7.325 pushrods. I need to get a 8" caliper to measure the adjustable rod though.
Where's the best place to get a set of PRs in a hurry? I looked on Summit and didtn't see what I need. I suspect I'm not searching correctly.
Old 09-14-2010, 09:33 PM
  #200
1Bear's Avatar
It's a pretty decent little book. It doesn't go all crazy over high performance aftermarket parts, even though it does cover things such a setting up rocker arms and such. It just gives a lot of good tips for engine assembly of LS Type motors. I would say it's definitely a good addition to any motor heads library.
Quick Reply: 6.0 Buildup - Your advice wanted.
