6.0 Buildup - Your advice wanted.
Old 09-14-2010, 09:38 PM
  #201
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by 1Bear
It's a pretty decent little book. It doesn't go all crazy over high performance aftermarket parts, even though it does cover things such a setting up rocker arms and such. It just gives a lot of good tips for engine assembly of LS Type motors. I would say it's definitely a good addition to any motor heads library.
Cool deal, thanks Jarrod...as you mentioned, I figured that the worst case scenario, if it didn't have all of the info I need, at least it would look good on the shelf along with the few other GENIII books that I have
Old 09-14-2010, 09:43 PM
  #202
blsnelling's Avatar
Are these the right pushrods, LINK?
Old 09-15-2010, 12:49 PM
  #203
blsnelling's Avatar
The pushrods are ordered. Obviously, I'll have to remove the valve covers again to install them and the rockers. The trunion upgrade kit is already installed and ready to go. Still waiting on the coolant crossover lines and injector clips. It's almost time to move the engine over, and move the truck into the garage
What is the torque on this style of intake bolt? My book shows a different bolt and torque spec that mashes the rubber isolators out.
Old 09-15-2010, 01:13 PM
  #204
TOTM: June 2007
bgray's Avatar
let em look into the spec on that in mitchell for yah....
Old 09-15-2010, 01:21 PM
  #205
I have a gauge for that
Atomic's Avatar
How was the trunion upgrade for the rockers? Someone suggested that for me since im using stock rockers but I never did it...
Old 09-15-2010, 01:27 PM
  #206
TOTM: June 2007
bgray's Avatar
I also ahve rodered the Trunion for my 6.0L....very cheap upgrade, and as they say....when in rome
I looked up that torque spec it says Intake maniofld bolts in first sequence 44 inchlb, then on second pass 89 inchlb's
I subscribe to mithcell so if anyone needs some info just ask
Old 09-15-2010, 01:33 PM
  #207
blsnelling's Avatar
That's what my book says too. But the bolts shown do not have these rubber isolators. They cannot take that kind of torque. They just mushroom out from under the bolt head.
  #208
blsnelling's Avatar
It was a piece of cake with a $50 Harbor Freight arbor press.
Old 09-15-2010, 01:42 PM
  #209
TOTM: June 2007
bgray's Avatar
Your doing it in INCH lbs?
Old 09-15-2010, 01:50 PM
  #210
Dezert1500's Avatar
I doubt he's using 44 ft/lbs then backing that up with 89 ft/lbs haha.
I don't have my book infront of me, but I know it's not much. I normally can do them by feel and visual. I'm sure it's a similiar torque as the valve covers. Those back oil pan bolts are sketchy too. They always feel like they are going to strip.
Quick Reply: 6.0 Buildup - Your advice wanted.
