6.0 Buildup - Your advice wanted.
Old 09-15-2010, 01:52 PM
  #211
blsnelling's Avatar
Yes, inch pounds.
Here's what the bolts look like. Do I have the right bolts? I got them from another member. Maybe they're not for this particular intake.
At 89 in/lbs, the bottom shoulder of the spacers is in contact with the head. At 30, it is not.
Here is torqued to 89.
This is only 30 in/lbs.
Old 09-15-2010, 02:12 PM
  #212
blsnelling's Avatar
I pulled one of the bolts out of my truck. They're identical. Also, I believe the bolts pictured in my manual are the same. You just can't see the rubber isolators with the picture being taken from directly above.
But I figured out what it is. I think it's due to the heads being milled .035". If I put a small washer on the end of the bolt, it works fine.
Old 09-15-2010, 02:14 PM
  #213
TOTM: June 2007
bgray's Avatar
I would nto stress to much over it, I would snug them up till they start to plumb out, when i removed my intake a week ago they were not very tight at all
Old 09-15-2010, 02:15 PM
  #214
blsnelling's Avatar
I'll either put blue loctite on them, and set them how they need to be, or I'll get 10 washers of the right thickness. Easy peasy. Just wanted to figure out what was going on.
Old 09-15-2010, 10:52 PM
  #215
blsnelling's Avatar
I got the fuel rail spacers made tonight. These are stainless steel. It's good to have a machinist for a friend.
I measured my adjustable pushrod, and I ordered the correct size Preload will be .050"-.065". 7.350" PRs would have pushed me to .088" preload.
Old 09-15-2010, 10:59 PM
  #216
brent5631's Avatar
Good to see the swap worked for ya!
Old 09-15-2010, 11:28 PM
  #217
PT's Slowest Truck
budhayes3's Avatar
Looking good b, those spacers are really nice. I forgot that you're using the TBSS manifold...now I remember why you needed spacers with your 8.1 injectors
Old 09-16-2010, 09:39 AM
  #218
blsnelling's Avatar
I just ordered my Black Bear tune. I'll be pulling the truck into the garage tonight and pulling the PCM. Any recommendations on what my shift points and rev limiter should be? I don't want to rev this thing to the moon looking for every last ounce, at the expense of long term reliability. My current tune is set to 6000 shifts. I am willing to go a little higher than that. So it boils down to, what's a reasonable minimum shift point for this setup?
Old 09-16-2010, 12:04 PM
  #219
PT's Slowest Truck
budhayes3's Avatar
I'll bet that you could shift at 6300 and still be pulling no problem...you could shift higher if you wanted, but I'd guess around 6300 as a min...
Old 09-16-2010, 12:54 PM
  #220
TOTM: June 2007
bgray's Avatar
I was gonna say 6500rpm for being up there. My black bear is the 3rd setting for shift pressure and it tops into gear pretty good...maybe to mcuh for some people
Quick Reply: 6.0 Buildup - Your advice wanted.
