6.0 Buildup - Your advice wanted.
Old 09-17-2010, 11:35 PM
  #261
brent5631's Avatar
I really hope you didn't destroy the trans pump when you pulled it like that. Its been known to happen.
Guess I'm late.
Old 09-17-2010, 11:41 PM
  #262
blsnelling's Avatar
I don't know what the tranny looks like inside to understand how that would happen. Anyway to inspect it now? I tried hard not to put too much force on the shaft.
Old 09-17-2010, 11:49 PM
  #263
brent5631's Avatar
It doesn't take much. Just enough to break the little pump ring inside the pump. Besides removing the tranny its not too hard to fix just a new pump.
Old 09-18-2010, 12:05 AM
  #264
blsnelling's Avatar
Could the pump just be pulled from the front of the trans right now and inspected?
Old 09-18-2010, 01:05 AM
  #265
blsnelling's Avatar
So do I take my chances and put it back together? Or, do I drop the pan, remove the TC lockup solenoid, and pull the pump out the front for inspection?
Old 09-18-2010, 07:48 AM
  #266
I have a gauge for that
Atomic's Avatar
In my case I broke the pump rotor ring, but as long as you can use a very thin screwdriver to stick in there and spin it by hand and the torque converter seats properly it should be ok...
Old 09-18-2010, 09:25 AM
  #267
blsnelling's Avatar
I'll check it out. Thanks guys!
Old 09-18-2010, 03:14 PM
  #268
PT's Slowest Truck
budhayes3's Avatar
At the very least I'd replace the front pump to converter seal, and with the seal out you'll get a better view of the pump
Old 09-18-2010, 11:06 PM
  #269
blsnelling's Avatar
I did pull the front seal. The pump turns freely and easily. I'm hoping that I got lucky. I was able to find a seal and lockup o-ring. Matter of fact...I'M DONE!!! Yup, that's right. All that's left is installing the intake tube reducer once it comes in, connecting hose from the front of the passenger's side valve cover, and installing the PCM when it arrives. It took about 8 hours to install the engine and wrap everything up.
As far as connecting the hose from the passenger's side valve cover, there's what appears to be a block-off screw in the top of the t-body. I'm thinking that all I need is a fitting to screw in there and connect the hose to it.
We got one BIG scare. I was dumping antifreeze in it when it started just pouring out the back of the engine. I was horrified. It turned out to be nothing more than a plug left out near the back of the passenger's side head. This is where the coolant temp sensor would be if the heads were swapped from side to side. I had simply missed taking it from the 5.3 when swapping parts.
A BIG thanks goes out again to my brother Brian and good friend Paul. They're the ones that made this swap possible. It was awesome to be under the truck or setting in the engine compartment and ask for this, and ask for that. It made the install so much easier. I'm still so soar and tired I can hardly move, lol. This is hard work fo ra 42 year old
My wife really got a kick out of this
Here it is all wrapped up. It's a real shame that pretty orange is all covered up
Old 09-18-2010, 11:46 PM
  #270
Atomic's Avatar
Awesome man! Having help must hr nice, I did my engine swap by myself and it took me 3 days
Quick Reply: 6.0 Buildup - Your advice wanted.
