6.0 Buildup - Your advice wanted.
#272
I need some advice on my cruise control. First of all, the tab on the TB is larger than on the original. How can I connect it? Second, is it ok for there to be about 3/16" slack in the cruise cable at idle? That's with the adjustment as short as possible.
#273
So, I'm going to have to come up with another way to plumb the vac hose. I'm thinking I'll use a 1/4" NPT to 6AN fitting. I can either drill and top the t-body, or go into the intake tube. I like the idea of a nice solid fitting in the t-body. Thoughts?
#277
I let it idle for 8-9 minutes, which had it up to temp for a while. No leaks, good temp, and excellent oil pressure. I fogot one small thing. I didn't block off the EGR port on the passenger's side header. I let it go for the first heat cycle. I've got it blocked off now.
One issue. It's idling at 1700-2000 RPMs. Does the engine have to be started and turned off a few times for the IAC valve to reset?
#280
I don't have the intake reducer yet, so I have it sealed up good with black duct tape. I don't believe there are any leaks there.
The initial high idle problem was my throttle bracket. I had a little too much tension on the cable. I slotted the holes and took care of that. However, the idle is still not consistent. Somtimes it's 700, sometimes it's 1000.
The biggest problem I have now is with the shifting tune. It's going into 3rd and lockup at 25MPH. Of course it lugs like crazy when it does that. I'll get that ironed out with Jason. He did this tune in a hurry for me. I really appreciate him going above and beyond to get me running in a hurry.
I went by the dealer and got the crank relearn done. I had forgotten that require a quick burst of WOT. It shocked me, but sure sounded awesome. It grabbed RPMs INSTANTLY! Wow! I guess that's what higher compression does for you.
I've got 14 miles on it and changed the oil. I'm letting it cool before I drive it anymore.
I'll have a vid up shortly.
