6.0 Buildup - Your advice wanted.
Old 09-22-2010, 07:49 AM
  #321
blsnelling's Avatar
Originally Posted by GMCtrk
They look like Denso sensors, they're just as good, if not better than the older OEM style.
My Denso's don't like my big headers though, not enough heat to keep them happy.
Perhaps I replace them and simply forgot Am I mistaken that O2 sensors do not affect the engine until warmed up and in closed loop? If so, then they have nothing to do with the bucking and back firing, correct?
  #322
TOTM: June 2007
bgray's Avatar
All your issues are within your tune. You really need to buy a Wideband 02 sensor as stated above, it will tell you what is comming outta that motor, and will allow you to monitor it accordingly
  #323
blsnelling's Avatar
Anyone have EFI Live, v1 or v2, that they'd want to sell? I'm definately in the market.
Old 09-22-2010, 07:50 AM
  #324
blsnelling's Avatar
So now you not only want me to buy EFI Live, but you want to further drain my bank account and buy a wideband O2
Old 09-22-2010, 08:07 AM
  #325
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Ive had better luck with bosch, they toggle better and last longer, they have a spherical end instead of a cylindrical end.
Old 09-22-2010, 08:09 AM
  #326
1slow01Z71's Avatar
A wideband should be standard equipment with any tuning software
Old 09-22-2010, 08:12 AM
  #327
blsnelling's Avatar
Which one then
Old 09-22-2010, 08:30 AM
  #328
1slow01Z71's Avatar
Innovate LC1, its got a digital output so its better. You can get it from Kbracing96, I got my EFI and wideband from him. Good guy to deal with.
Old 09-22-2010, 08:40 AM
  #329
blsnelling's Avatar
Yes, he was very prompt with his PMs last night.
Old 09-22-2010, 08:42 AM
  #330
blsnelling's Avatar
I just put a fuel pressure guage on it. It was reading 50 PSI at idle. This is on a cheapy Autozone guage. I swapped in the pressure regulator from my 5.3, and it's now 54 PSI at idle, and about 52 with a few RPMs. Is it normal for it to fall for a split second when you blip the throttle? Also, the needle "quivers". I'm assuming this is normal?
Probably time to change the fuel filter if nothing else. It's been a while.
Quick Reply: 6.0 Buildup - Your advice wanted.
