6.0 Buildup - Your advice wanted.
Old 08-24-2010, 09:56 AM
  #61
blsnelling's Avatar
I'm not shooting for a specifc power lever. I'm just trying to build a solid engine with known good performance upgrades. I'm hoping for a little over 400, but that's just a guess. I did not get an answer on the CR. I'm thinking it should be about 10.7:1 wil .051 gaskets.
Old 08-24-2010, 09:59 AM
  #62
blsnelling's Avatar
I just this morning learned of the Fel-Pro 1041 gaskets. These are .041" thick. However, the bore is 4.135". Is that too big on this setup? Am I correct in thinking that the diameter of the combustion chamber will be a little larger on my 243 heads once they're milled .035"? I'm not worried about reuseability, or being harder to clean up, should the need arise. I just don't want to use Cometics, so it's either these or GM gaskets.
Old 08-24-2010, 01:59 PM
  #63
blsnelling's Avatar
For the build I'm doing here, is there any need for me to upgrade from GM rod bolts? I'm hoping for 400-425 HP and will not be spinning it over 6000-6200. GM bolts are $62 and no concerns with the rods needing resized. Katechs are $200. ARPs are only $90, but questionable on needing resized.
If I bought ARPs, could I simply bolt the caps on and check for out of round, or is there more to it than that?
I want to build smart, but don't want to throw money where it's not needed.
Old 08-24-2010, 02:30 PM
  #64
blsnelling's Avatar
The first of the goodies has arrived Yank PT3200.
Old 08-27-2010, 11:33 AM
  #65
blsnelling's Avatar
Will my stock 5.3 injectors be sufficient for this build?
Old 08-27-2010, 11:46 AM
  #66
PT's Slowest Truck
budhayes3's Avatar
I don't think so....with a 220/224 cam in a 6.0, and head work, I think that you'd even be pushing the limits of 31# 8.1 gas injectors. I'd go with the 8.1 marine injectors to play it safe, they're 42# I believe. Plus, if you ever go bigger on the cam, you should still be able to reuse them.
As for the rod bolts, I believe that the stockers will be fine, but some upgraded rod bolts are cheap insurance. Check the internal section for a thread I started calle "ARP Rod Bolt Roll Call", there's a bunch of good info in there. From what I remember, the ARP's are a direct replacement as long as you remove the sleeves that are in there. The Katech's are a direct replacement and the last rod bolt that you'll ever need, but as you already know, they're big bucks :nod;
Old 08-27-2010, 11:56 AM
  #67
blsnelling's Avatar
Are those 8.1 marine injectors the correct lenth for the TBSS intake? Are those PN 17113739? That PN doesn't come up at SDPC.
Old 08-27-2010, 02:00 PM
  #68
blsnelling's Avatar
Another new part today. Thanks Yank, for the LS2 HD timing chain and gears!
Old 08-27-2010, 03:09 PM
  #69
PT's Slowest Truck
budhayes3's Avatar
Not sure on that one, they're plug and play for the truck intake, so if the TBSS intake is different, then no...
Old 08-27-2010, 04:04 PM
  #70
GMCtrk's Avatar
If you wanted to build smart, you would leave everything as it is. There's absolutely no reason to change any rod bolts, timing chain, oil pump, lifters, etc. I firmly believe all these "must change" myths were started by vendors trying to make an extra buck.
Quick Reply: 6.0 Buildup - Your advice wanted.
