6.0 cam?
6.0 cam?
im putting 6.0 in my obs chevy.i would like to know what you guys recommend as far as a good street/track cam more track than street the truck will only be driven occasionally to work (2 miles away from home)and local cruise in. im not concerned about how high of a stall i will need since it wont be a daily driven truck. thanks in advance guys..
keep in mind motor is stock will only run long tube headers and a good tune after the cam is installed
I run a texas speed tv.2 cam in my 6.0 camaro, lots of mid range to top end power.
232 234 .595 .598 on a 113 is what I have, drives real nice but at the same time pulls hard all the way to 6,600rpms.
If you chose this cam I would also think you would need 4.56 gears and 3,000 stall to make it work properly
keep in mind that you have a heavy ecsb compared to a rcsb or car....i have a tr224 with a 3400 stall and 3.73s in a rcsb and it is fun to drive around, streetable and quick too. i would say stick to a 224-228 cam for best results....good luck...rob.
thamks man for your advice but its goin in my 89 rcsb truck..
thanks alot guys this really narrows it down some
