6.0 cam in a 5.3
Old 03-27-2004 | 12:45 AM
02chevyracing's Avatar
14 Second Truck Club
Default 6.0 cam in a 5.3
i was wondering if these cams are the same? if not has anyone done it and saw any gains?
Old 03-27-2004 | 01:37 AM
Banned
the 6.0 cam is a little different than the 4.8/5.3 version, but a swap from one to the other in my opinion is pointless for the 5hp you might gain for the time effort and money involved in the swap. just save a little and get a custom grind and do the swap if you really want to see results.
Old 03-27-2004 | 08:18 AM
BigTex's Avatar
Here, this one is cheap. You'll see 30 rwhp gains with this cam. Many 5.3 guys have run this baby. Works great with LS6 springs. You can probably pick it up since you probably live close to the seller:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2469121405
Old 03-27-2004 | 09:08 AM
anybody have anymore suggestions thanks Tex
Old 03-27-2004 | 09:46 AM
F8L Z71's Avatar
The one Tex posted would work great. Just be sure to have someone check your lifter pre-load after the install. Some cames have smaller or larger base circles and if you simply install them you'll end up with too little or too much preload and will need to run different length pushrods.
Old 03-28-2004 | 10:19 AM
what about a 99 fbody cam?
Old 03-28-2004 | 10:20 AM
F8L Z71's Avatar
Why do you wanna go so small??
If you wanna go cheap then get the 02' Z06 cam and an adj. timing chain. Otherwise spend the money and get a good cam the first time.
Old 03-28-2004 | 03:24 PM
BBLS1's Avatar
I Like Gold!!!
hey chevy racin truck i have an ls6 cam with springs for sale. lmk
OLD BULL
08-01-2015 05:00 PM
elpyro89
07-28-2015 05:51 PM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: 6.0 cam in a 5.3
