6.0 guys how much are you overbored?
Mr. Obvious
i know on the trucks most everybody is using a 6.0L truck iron block and boring it .030" over for a 370 with stock stroke or a 408 with 4" stroke. a 402 would be stock bore with 4" stroke.
if you are just wanting to rebuild it, go .030" over. if you are looking for the max bore you can get, get the block tested to see how far you can go and then go from there.
