6.0 Installed And Won't Turn Over!!!
#21
Originally Posted by gmtechnician
next thing to check would be your relay to see if it clicks while you try to crank.
#22
any ideas??? it's not the relays, or fuses, and the starter is still good. The mechanic i talked to said that it was my computer and needed it reprogrammed but i just got this from Nelson made for all my mods... so that's not even an option is it?
#24
if the relay clicks then you know your getting power and ground to the control side of it. you should have power at two terminals on the relay and ground at one other terminal with the key on. then when your key goes to crank, you will get ground at the other terminal. so check to see if you have two powers with the key on. if you dont then its just going to be finding out where the powers come from and go from there.
#25
Originally Posted by DLH2006
it could be but i doubt it, unplug the pcm and when you plug it back in make sure it is connected correctly and everything is tight!
When you installed the PCM did you disconnect the battery?
03regcab sierra
20
08-03-2015 12:11 AM
signguy62
07-27-2015 03:42 PM
InsaneDomestics
07-27-2015 02:42 PM
atxlt
07-20-2015 11:06 PM
mr03silverado
07-17-2015 02:15 PM
