6.0 questions paging BIGtex,parish, 6.0 guys
Some guy a has a COMPLETE 6.0 motor its a GM surplus motor he acutally has 2 but hes not sure wether its an LQ9 or Lq4 he said when he bought htem they told him it was the latest year 02-03 but he tells me it has steel heads? i thought both the new LQ9 and the LQ4 had aluminum heads? what motor does he have? is there anythign on the motor that can distinguish between year and type? he tried calling dealers wiht the serial number but since its surplus they cant tell him either... and if i get htis motor and it does have iron heads what heads should i put on there for my kit?
Re: 6.0 questions paging BIGtex,parish, 6.0 guys
The 99-00 lq4 motors are the only ones with cast iron head the part # is 12561873. The last three digits will be stamped on the heads. I believe those year blocks are interchangable, but have problems with crank length and i believe they cant be bored very much. If your will to put down the bucks. The Lq9 and ls6 heads are pritty much idenitical flowing heads. Both are aluminum.
naw i guess this isnt worth it then i only wanted it cause its a COMPLETE brand new motor 0 miles i want a LQ4 fast cuz i need to get my truck running again and i want to keep my procharger...
The LQ9 pt# is 12572035 and the ls6 is 12564243
my 01 6.0 heads are 317s,GMHTP says LQ4 2001 up are P/N 12562317.Then they say 2002 LQ9 6.0 is P/N 12572035 but this border line rag doesnt give a casting number for that head.Bastards.Some so called experts think there is a difference in port design in these heads while others are saying they are the same.I am going with them being the same based on having the same casting #s according to BiG-TeX
