6.0 Radiator
Old 07-14-2004 | 09:50 PM
silent1's Avatar
Originally Posted by GMC SKI
just get a re-core on your old rad like i did for $125.00
they reuse your end tanks and put a new core in
Radiator Barn can do this?
Old 07-14-2004 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
Will a 6.0 34" radiator drop right in? No modifications?
Old 07-14-2004 | 10:02 PM
GMC SKI's Avatar
rad barn won't do it ..local guys will
Give your local guys a call and see what prices are
Old 07-14-2004 | 10:12 PM
Hit Man X's Avatar
I was wondering if it'd be possible to run a two core 34" wide one... ?
Old 07-14-2004 | 10:42 PM
XLR8NSS's Avatar
Adkoonerstrator
You talking about a custom one?
I don't see why not, there is tons of room with electric fans. Nothing will get in the way of a slightly thicker radiator. Just mount it with the extra thickness mounted to the engine bay side.
Old 07-14-2004 | 11:31 PM
JSmith's Avatar
Yes, it will drop right in. There are lower mounting holes already in place as well as threaded inserts for the bolts on the front firewall for the wider radiator. All you have to do is trim the rubber that sits in front of the radiator.
Old 07-15-2004 | 11:47 AM
BigKID's Avatar
Just got mine from radiator barn a few days ago. That brings up a question though. I was looking at the wider set of bolt hole in the support and one of mine is being used by my GenII. Anyone done this swap with the K&N GenII setup?
Old 07-15-2004 | 05:21 PM
VortechC5's Avatar
Does the 5.3 fan shroud fit or do you need a wider fan shroud to fit the 6.0 radiator?
GMCtrk
18
10-06-2015 03:48 PM
turbo6c3
10-05-2015 06:11 PM
Cammed4ever
09-30-2015 03:38 PM
old motorhead
09-29-2015 08:22 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: 6.0 Radiator
