6.0 swap?
Old 08-19-2005, 05:38 PM
seeyaa's Avatar
Default 6.0 swap?
found 2004 6.0 forsale do you guys think it would make a huge differance from what i have right now.if so how much thanks.
Old 08-19-2005, 05:40 PM
Mr. Sandog's Avatar
2000 Lm7 = 285hp
2004 Lq4 = 325hp
2004 Lq9 = 345hp
Old 08-19-2005, 05:50 PM
seeyaa's Avatar
right now Lm7 with everything in my sig. Im not sure if it is a lq9 how do i tell.
Old 08-19-2005, 05:57 PM
seeyaa's Avatar
it dose not come with the wiring harness will my stock harness work
Old 08-19-2005, 06:00 PM
Ruffrider5.3's Avatar
It will just be a long block swap so you will reuse accesories and intake. The LQ9 block will be aluminum, the LQ4 block is iron.
Old 08-19-2005, 06:10 PM
Mr. Sandog's Avatar
Actually, they're both iron. And yes, it is a direct swap.
The reason I didn't comment on your bolt-ons is because they will all be used with the new motor, so any gains (CAI, TC, etc.) will be swapped over as well to the new setup.
Old 08-19-2005, 06:13 PM
gonzo 6.2's Avatar
LQ9 is an Iron block
The 6.0 and proper tune with a cam specific for your needs will create a ton more torque than you have now,thats what you need in a fullsize heavy truck.Might saw off 1-1 1/2 off your quarter mile
Old 08-19-2005, 06:24 PM
seeyaa's Avatar
so guys how do i tell if it is lq9
Old 08-19-2005, 06:27 PM
gonzo 6.2's Avatar
If its cheap enough it wont matter,but a LQ9 is worth more,look into the sparkplug hole and if it has flat top pistons its a LQ9,LQ4 will have dished.
Old 08-19-2005, 06:29 PM
seeyaa's Avatar
i have not seen the motor its in texas and im in michigan
Quick Reply: 6.0 swap?
