Is the 6.0L Internally or Externally balanced?
the spacer for the 01+ is to allow it to work with the 80....a 00 motor has this built in. GM never intended for the first 6.0s to be "hot rodded". they swapped to the aluminum head 6.0 and then used the standard lenght crank. making the 00 motor worth less, minus it being a core
I was under the impression that the 2000 V6s, 4.8 V8s and 5.3 V8s were all the short crank and the 6.0 V8 was the long crank. But actual measurement will tell for sure. If you measure from the mounting face of the block to the flange face on the crank, and they both are the same, then I am wrong.
