6.0l swap question...fuel lines
hey guys im not trying to add to the repetition of swap questions but i couldnt find it and was wondering if anyone could help me out. i was told somewhere that since im swapping a 6.0l into my truck witha 4.3l stock , that my fuel lines wont mate up.
wat can i do here /what do people normally do?? i thought i saw a picture of a motor that had some stell braided performance loking lines but......im not sure on anything fuel related.
any help would be great here!
thanks
thanks
Fuel Lines: The stock fuel lines will not work with the new motor, you will need
2 EAR-165056ERL -6 - 5/16 AN to tubing connectors Male end
2 EAR-165006ERL -6 - 3/8 AN to tubing connectors Male end
2 RUS-658490 1 ft sections of pre assembled 5/16 Steel braided hose with female ends
Simply attach one 5/16 to -6 tubing connector to the fuel rail on the intake manifold
Then attach the 3/8 to -6 tubing connector to the return line on the fuel rail on the manifold the above PN#’s are from Summit Racing
Cut the fuel “tubing” about 6 inches below the firewall and follow the same steps as above. Now attach the hoses to the fittings which are now on the tubing. MAKE SURE the fittings are on snug! Now when the time comes to hook up the lines simply screw on the lines to the manifold.
Note: be sure to label the lines, Fuel and return. Fuel being the larger line and the return the smaller in diameter.
is this the best way to do it......i def dooo not want ne trouble with leaks...it sounds scary with compression fitting on the stock lines by the fire wall....
oharajo
07-18-2015 09:24 PM
mrgrim
07-08-2015 08:12 AM
Nimoryan
07-05-2015 03:50 PM
