6.0l tune
6.0l tune
does any one have a tune for a 6.0l so far the most ive got to the wheels is 250hp and 290tq with a 2004 6.0 i used edit and copied and pasted the fuel and spark from a 2003 6.0l ss silvarado i just know i can get more power from this thing just wondering thanks
if any one has a tune that will work it will be greatl
thanks for the help
btw its in a 2000 gmc 1500 ecsb w/4l60e
thanks for the help
Formerly one92rs
are you using edit?? hptuners? either way there is a lot to change and gain performance with. i would begin by adding some timing to the upper rpm's on the table. man i can go on and on. and if you are planning on buying a tune there are sponsers that do kick *** tunes.
im using ls1 edit its a lq4 out of a 2004 4x4 2500hd truck i used the tables out of a stock 2003 ss truck that i downloaded from ls1edit.com when i took it out on the highway the truck pulled hard i had the spedo pegged out and the tach was at about 5000rpm (some where around 130) i let out cause the truck started to float but the motor was pulling hard still
From what little I've seen of trucks, there is a lot of spark
left out, the PE is applied late and slow, burst knock is so
sensitive that it gets applied during normal acceleration.
I don't know if Edit can read "straight" binaries like the
HPTuners .bin (which is unencrypted like honest software
should be). But if so you might want to take a look at all
the .bins on Horist's repository site (see sticky). If this
doesn't work for you, I'd look to the late F-body tunes.
If you post "gimme tables" requests in the PCM section I'm
sure you could get plain-text examples of other platforms'
key tuning tables.
key tuning tables.
ARC
57
02-21-2022 10:54 AM
FlowmasterMufflers
10-26-2015 06:19 PM
JFortner5
08-20-2015 06:13 PM
FlowmasterMufflers
08-14-2015 01:04 PM
oharajo
07-18-2015 09:24 PM
