6.2L (L92) Differances?
Old 11-08-2007, 07:17 PM
1TRUESS's Avatar
Default 6.2L (L92) Differances?
What is different between the L92(403hp & 380hp). I know that the LQ9 and LQ4 it was the pistons, but how do they get the different HP from 380 to the 403hp L92?
Old 11-08-2007, 07:21 PM
What vehicles have the 403 and 380 hp versions of the L92 or is it an option?
Old 11-08-2007, 07:23 PM
1TRUESS's Avatar
I found this info and got even more confused?!?!?!?!
The 2007 Cadillac Escalade has a 6.2 L Vortec 6200 (RPO L92) engine. It is an all-aluminum design which, while still a pushrod engine, boasts variable valve timing, a first in a mass-produced non-overhead cam V8 engine. The system adjusts both intake and exhaust timing between two settings. This engine produces 403 hp (301 kW) and 417 ft·lbf (565 N·m) in the Cadillac, but was inexplicably only rated at 380 hp and 415 ft·lbf in the earlier versions of the GMC Denali.
Old 11-08-2007, 07:24 PM
1TRUESS's Avatar
403hp is in the Sierra Denali and the 380hp in the Yukon Denali
Old 11-08-2007, 07:27 PM
WTF? So is it more a tuning difference in combination with some new technology that I have never heard of. Now I am confused. Maybe someone else will chime in.
Old 11-08-2007, 09:00 PM
05GMCL33's Avatar
Variable valve timing has been used by other auto manufactures for some time now such as the Honda VTEC and Toyota VVT-i. Variable valve timing does add good power, a good power band, and good fuel economy without changing the camshaft profile. It look's like to me that GM incorporated this technology with there pushrod V8 engine. I think this is a very good idea to get the most power and fuel ecomomy out of the LSX engine.
Old 11-08-2007, 10:11 PM
LMSeven's Avatar
It might be the RPM they are rated at. IE the 403 hp 6.2 might be rated at 5800 rpm vs the 380 hp 6.2 being rated at 5200. If they have the same engine code then Id say its the tuning. GM might under rate the Yukon for whatever reason, when in reality it lays down the same numbers as the sierra and escalade. Those are my only guesses.
Old 11-08-2007, 11:49 PM
Vortec MAX's Avatar
I remember reading someplace that they were going to tune the Denali differently because they wanted the Cadillac to be the more desirable (more powerful) vehicle choice. There are not any mechanical differences that I am aware of.
Mike
Old 11-21-2007, 08:48 AM
Mark Johnson's Avatar
Say- how big are the valves on the L- 92, found it gets lousy gas mileage........
Old 11-21-2007, 07:09 PM
r3dh4tch's Avatar
2.16 intake, 1.59 exhaust valves
Quick Reply: 6.2L (L92) Differances?
