6.2L - Removing VVT
Having said that, what I would like to see is someone do a test between a VVT cam instal and a similar spec cam without VVT in a 6.2L to see what if any power gains there are from the VVT.
I have done this before. I used a gen 3 pcm with a gen 4 engine. I use a 2005 ls2 front cover and upper timing gear. I changed the reluctor on the crank to the 24x. Pressed on, but very vital that it is oriented exactly right. The crank and cam sensors must be 05 and prior. Lastly, the knock sensors must be located externally. Otherwise, now there is a 58x to 24x converter box available from LPE. I have not used it, but it is simpler. BTW, the cam also must be changed to the 3 bolt style too.
