628hp 680tq 16psi no nitrous
Old 10-05-2004 | 05:00 PM
  #41
Scream's Avatar
MOOBIES Moderator
All I got was pics of the dyno sheet...
Old 10-05-2004 | 05:15 PM
  #42
parish8's Avatar
single digit dreamer
f#$K!
Old 10-05-2004 | 05:17 PM
  #43
parish8's Avatar
ok, try it now
Old 10-05-2004 | 05:32 PM
  #44
Scream's Avatar
MOOBIES Moderator
still getting a dyno sheet...
Old 10-05-2004 | 07:42 PM
  #45
parish8's Avatar
i am prety sure it is working now. you may have to refresh it somehow. it is being hosted at another site but i wanted it to goto my site first so i can track it.
Old 10-05-2004 | 08:02 PM
  #46
Scream's Avatar
MOOBIES Moderator
Got it from the other thread...thanks!
Old 10-05-2004 | 09:26 PM
  #47
zippy's Avatar
works for me.
Old 10-05-2004 | 09:32 PM
  #48
zippy's Avatar
if you check out the open cut-out at 15.3 psi run you can see the spark going through the spark plug.
Old 10-05-2004 | 09:56 PM
  #49
parish8's Avatar
hmm, is that what that is? do i have a problem or is that normal?
Old 10-05-2004 | 10:01 PM
  #50
zippy's Avatar
normally you only see that on a spark plug that miss fires under load. with the boost you were running it's hard to say if it is normal or not to see the spark through the ceramic. alot of times if i'm chasing a miss that i think is spark related i'll check for this in the dark, but under that kind of cylinder pressure i don't honestly know how it should act.
Quick Reply: 628hp 680tq 16psi no nitrous
