703 RWHP 4x4 6.0L
703 RWHP 4x4 6.0L
Just got our F1 project truck done and dynoed. We through it on the dyno with 8lb. of boost and we happy to see that it dynoed 703 RWHP. Still having a problem lifting the heads though. Any time we go above 8lb. of boost we have problems lifting the heads. We need to put bigger studs in the heads down the road. The setup includes:
-6.0L block
-Custom Diamond Pistons
-Lunati Rods
-Stock Crank
-LQ9 Heads with bigger valves
-AZ Longtubes
-Blower cam
-& we keyed the crankshaft
You guys can check it out if you like. (Link)
Sean
-6.0L block
-Lunati Rods
-Stock Crank
-AZ Longtubes
-Blower cam
Sean
That's impressive!! I still would have to side with parish though. The procharger won't make the torque parish would with the turbo. although very impressive in deed!! Parish needs a set of heads for his 408, then 700rwhp no problem!! Wouldn't mind seeing the two trucks it out!!! awesome
Whoops, now that I see the truck, really not a good match up, two completely diffrent set up's
