8.1, 6 speed allison
Old 01-25-2007, 03:45 PM
Kerr's Avatar
Default 8.1, 6 speed allison
Was looking on e bay and there are just a few 07 models on there.. I noticed the 8100 now have listed the 6 speed allison with the "paddel" shift option on the shifter.
Just wondering if anyone has driver one and what kind of difference it makes. Also do you know if spits the gears some place or is it just two over drives now...
Old 01-25-2007, 05:07 PM
2006 8.1's Avatar
I have one. I like it. I think it shifts smoother than my 05 diesel I had. Basically, the trans is exactly the same as the 5 speed, they just added another overdriven gear. 5 gear was overdriven, and 6th is overdriven 10% more than fifth. At 75, I am at about 2000 rpms with 265/75rR16 tires, and 4.10 gears. Mine is a 3500 SRW, so it came with 265's stock.
The 8.1's are no more as of Jan 1st. To bad, I really like that engine.
Old 01-25-2007, 05:14 PM
yurs78's Avatar
Doesn't the allison come with 3.73 gears in the rear? What kind of mileage do you get with that set up? What are they going to replace the 8.1 with?!
Old 01-25-2007, 10:56 PM
2006 8.1's Avatar
If you have a D-max, you have to get 3.73 gears. But, with the 8.1, you got a choice of those or 4.10's. For the gas burner, the 4.10 are the way to go.
I think they are offering a hopped up version of the 6.0. It is supposed to have almost as much torque as the 8.1, but we all know, there isn't any substitute for cubic inches.
If I keep my foot out of it, I can get around 13. If I play, it is about 11.
Old 01-25-2007, 11:13 PM
Hydramatic's Avatar
urmmmm... F/I?
Old 01-26-2007, 08:48 AM
Kerr's Avatar
thanks for the info.. we have a 04 crew cab 6.0 with the 4:10... I just want a bigger motor... but dont want a diesel...
That extra gear helps with the rpms and milage i bet...
I read the info on the 6.2 it like 380 hp and 395 lbtq or something like that... far cry from the 455? or what ever the big block makes... that and nothing sound like a big block with parts
Old 01-26-2007, 01:44 PM
moes04silverado's Avatar
if you want the 8.1L in an 07 or newer you will have to buy a 4500 series truck. GM eliminated the 8.1L in the 2500 and the 3500 body styles
and i think the 8.1L only has 350hp @ 3200 rpm / 450 tq @3200 rpm....
also i think the pre 2006 models the allison was a 800 series, the new ones are a 1000 series....some correct that if its worng im a little unsure of the tranny models
Old 01-26-2007, 02:06 PM
3.73's and about 8-10 mpg with the K&N
6.2L in the HD2500 and 3500's
Old 01-26-2007, 02:59 PM
Kerr's Avatar
yea, your right, but i think you can still order a new 07 at least at www.chevy.com you can still build that truck.
Old 01-26-2007, 04:36 PM
2006 8.1's Avatar
Actually, the Allison 1000 was in all the 8.1 and diesels. I had a 2001 8.1, and two dmaxes with Allison's and they were all the same trans. Other than the fact that I have another gear in the 2006, the trans looks and acts just like the old ones.
I didn't realize you could still order an 07 classic. That would be the only way to get an 8.1, or find one on a lot somewhere. Hopefully, they will bring it back in 08.
Quick Reply: 8.1, 6 speed allison
