8.1 Aluminum cylinder heads and other new products
Old 03-09-2004 | 10:47 PM
tbyrne's Avatar
Default 8.1 Aluminum cylinder heads and other new products
This is a BIG POWER mod for your 8.1 motor! You'll be able to pick up 40+ horsepower and also take 100 lbs off the front of your truck with these aluminum cylinder heads.
Cylinder head specifications
Applications: GM 8.1 liter 8100 vortec (L18) engines
Mercury Marine 496MAG or 496HO
GM vortec Marine HP1, HP2, HP3 versions
Volvo Penta Marine GS8.1& GSX8.1 engines
Crusader 8.1 &8.1HO Captains’ choice engines
Indmar 8.1 & 8.1HO Malibu,Mastercraft engs.
Materials: Lightweight a356T56 Alcoa alloy aluminum
Heat treated and hard anodized for marine use
Method: Smooth cast
Machining: all required machining on 5 axis CNC centers
Valve seats: super alloy hardened high strength steel
Valve guides: manganese silicon bronze
Valve seals: super viton in steel "top hat" bodies
Valves: stainless steel EV8 with 11/32" stems, high flow necked stems with black nitride strength treatment after fabrication.
Valve sizes: Intake valve 2.20" x 12degree w/11/32" stems
Exhaust valve 1.725" x 20 degree w/11/32" stems
(Optional Inconel 1.725 exhaust valve x 20 degree avail.)
Rocker arm studs: Hardened steel with 8MM x 1.0 threaded top with
thrust nut base for mounting stock rocker arms with stock nuts, or
(optional) Raylar Stainless roller rocker arms with "all the way down"
adjusting nuts.
Intake Ports: 315cc. High velocity-High flow smooth ports
Exhaust Ports: 135cc.High velocity-High flow smooth ports
Complete Assembly: Includes:
Valves-intake & exhaust
Springs, retainers and locks
Valve stem seals, valve guides
Rocker studs and guide plates
Complete 5-angle valve job with
Back cut valves with special margins and radiuses.
Price - $2799.99 - free UPS ground shipping is being offered for all heads that are pre-ordered. We expect to start shipping these sometime in April!
A totally new intake manifold is in the late stages of development. It will allow much better airflow into this engine at all operating RPMs and allow it to develop more power and efficiency when combined with the new cylinder heads. This manifold will not create any added space considerations nor will it require any modification to stock or aftermarket marine configuration sensors, senders, injectors, fuel rails, brackets or hardware. Horsepower gains for the top end upgrades (heads and intake) will be in the 60-65+ range. More exact numbers will be available soon!
Other 8.1 products that you'll be seeing in the springs are - more aggressive cam grinds along with 1.8 ratio rockers.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
Old 03-12-2004 | 06:20 PM
Speedfreaks101's Avatar
What cc ports are the stock heads?
Do you have flow numbers for the stock heads vs these aluminum heads.
Thanks,
Bart
Old 03-12-2004 | 06:28 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
That's awesome! If only I had the money to throw down for a new Baja 30 Outlaw with twin 496HOs, then I could grab 2 sets from ya!
I'm surprised it took this long for someone to come out with an aluminum cylinder head for the 8.1, who makes them?
Rob
Old 03-13-2004 | 01:42 PM
tbyrne's Avatar
Don't have any cc or flow numbers for the stock heads yet but can tell you that these heads are made by Raylar.
I think my HD will be getting a set of heads and an intake. I'm resisting the urge to put them on the 496 that is in my Chaparral. I'd like to give that another 5 MPH on the top end (currently does close to 70) don't want to spend $3-4k to do it.
Tom
Old 03-14-2004 | 11:50 PM
Raylar's Avatar
Speadfreaks101:
The stock iron heads are 305cc and our new aluminum heads are 315cc. The flow numbers for the stock heads and our new heads are on our website @www.raylarengine.com. Just click on the cylinder head page on the products menu and then click on the flow data item and you will see the stock flows and the new heads flow for both intake and exhaust. Besides much better flow numbers the heads have a lot more port velocity, a quickburn combustion chamber and an extra point of compression up to 10 to 1 from stock 9 to 1. We just did some dyno pulls on a merc 496HO 425 HP motor and we jumped to 505HP with 85lbs more torque with just a head change and 5 lbs more fuel pressure.
Ray@Raylar
Old 03-15-2004 | 01:50 AM
Hit Man X's Avatar
CHOP
If you are referring to boats... I'd like a 36' Reggie Fountain!
Oobray
06-13-2022 03:38 AM
Denali08
08-09-2015 04:34 PM
BigEd_72455
08-08-2015 07:37 PM
sauldgold
07-23-2015 02:15 PM
Quick Reply: 8.1 Aluminum cylinder heads and other new products
