8.1 injectors ready to install
Old 08-28-2003, 02:15 PM
bigguy75inches's Avatar
Default 8.1 injectors ready to install
alright guys... i got a pair of 8.1 injectors so i can get rid of my whipple aux. injectors. what all is involved with the swap, and what should i set my ls1 file too?
Old 08-28-2003, 03:30 PM
hohl's Avatar
Default Re: 8.1 injectors ready to install
Set the IFR to 3.77 to start and tune your LTFT's from there. Change your PE table to make sure you don't go lean at WOT. You will also want to tune your injector offset -- Look for the stock values or ask for them on the ls1edit list.
Old 08-29-2003, 08:15 AM
is anyone here runnin 8.1 injectors?
Old 08-29-2003, 10:58 AM
hohl's Avatar
8.1 marine 43# injectors
Old 08-29-2003, 11:26 AM
GMC SKI's Avatar
I think you need to Clarify which ones you have
i think the automotive versions found in the truck are smaller
the Marine versions are larger i think
where did you get these things from ?
jim
Old 08-29-2003, 12:06 PM
hohl's Avatar
IFR in the 8.1 PCM for the stock ~30# 8.1 injectors is 3.77
IFR for the 8.1 marine 43# injectors has been tuned between 4.77 and 5.25. My marine injectors are set to 5.17 but I am sure it will change once I tune the offsets.
Old 08-29-2003, 06:04 PM
11 Second Truck Club
L-EATER's Avatar
If you got the truck ones it might not be enough to compensate for getting rid of the aux injectors. The Whipple uses 2 40lb'ers. Just something to think about.
Old 08-29-2003, 10:39 PM
how do i tell what i got?
Old 08-29-2003, 10:49 PM
ok... they are the stock truck ones. they flow at 30 pounds. will they work, or did i screw up and purchase the wrong ones?
Old 08-29-2003, 10:52 PM
i plan for about 7 or 8 psi once i intercool. so im sure im gonna need a bit more fuel.
Quick Reply: 8.1 injectors ready to install
