8.1L injectors for sidemount Magnacharger
Will the 8.1L Marine injectors be to much for a sidemount Magnacharger. It calls for truck injector application. Or if anyone can give a heads up for a good price on the truck injectors, let me know.
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
There is one advantage a M90 has over the Radix you can rev the supercharger higher without harmonics destroying the rotors.So the main issue is detonation not pulley size.You might be able to get performance similar to a stock Radix setup by spinning your sidemount Magnacharger higher and controlling detonation with alcohol injection.Your potential will be limited by the total amount of airflow through the smaller supercharger.If you go that route you'll have to really monitor your alcohol tank.
Injectors
I plan on having a custom tune anyways. I just needed to know if running the marine injectors would be OK. I spoke with Judd at Magnacharger, good guy, he was saying the kit came with the standard 8.1L truck injectors.
scooter k
09-16-2015 10:32 PM
2500, 81, 81l, avalanche, charger, chevrolet, chevy, injectors, magna, magnachager, magnacharged, magnacharger, marine, mount, side, supercharger
