80e install--screechin halt.
blownerator
Originally Posted by 02denali
you know it is closer to what i need. but even if i elongate the holes in it i think it would want to walk since the main two holes are a lot bigger than the bolts.
Hmmm. Well hell......Sucks because of the holiday everyone will be closed until Monday. Keep us posted!
Don't use the 60e flex plate because it has a different offset. I think maybe it was Snake Eater that had a problem where he used a 60e flex plate and the snout on the converter didn't go in the crank enough (because of no spacer), which caused it to be slightly out of balance. It ended up doing something bad I think.
I say hog out those holes on the 6.0 flex plate and call it done.
