86 Chevrolet Silverado 350 Edelbrock Carburateur Issues :( ???!!!
ok...I'm pretty sure its the Carburateur...Everytime I get in it I start it...it runs..as long as i keep in the gas as soon as i let off the gas...it kills the motor...even after the motor is warmed up I was wandering if ne one knew the Stock settings for the Carburateur like the 2 front screws...if i twist them all the way in..how far do i back them out..for stock..i can alter it as soon as i can get this ****** to idle...i just can't remember what the stock recomendations were on it..
Thanks Guys!!! ne other idea..would be appreciated.
ok..i got the idle Great now..in Park it sounds good..never Dies...
but then when i put it in Reverse It Boggs way down almost to the point of dieing and i push the gas and it stutters then all the sudden..it takes off...revved up high...every gear...it boggs way down til u get goin...WTF???is it doin this for?
Possibly a float level problem, I have a buddy going through about the same thing. adjusting the idle circuit helped very little. coming off idle is where the problem is. either a stuck metering rod or a stuck or saturated float. He's workin 12hrs a day now so I haven't had time to check more. good luck
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dude you are running dead rich off idle.... thats why it loads up once you hit the throttle then clears out after a second and goes.... you need to tune the idle to mid throttle transition.... possibly bigger rods?
