97 Chevy fuel pump problems..
Since you didn't specify if the pump is or is not working I"m going to assume it's not.
Check the wiring to see if any is bare? Make sure the ground is good.
Can you hook voltage up to the pump directly and get it to kick on?
Older pumps get shipped with a new harness that has to be spliced in, if thats the case on this one, make sure the wires are right?
Just throwing ideas, i remember doing one and the diagram given was worthless and we got lucky.
His wiring looks alright and yes the instructions are junk.. but there is no fire to any wires going to the pump.. the pump works I hooked it directly to the battery. If I cant figure it out soon Im just going to hook it up to a separate relay and have it turn on with key on. As he has to get back to college asap.
slowlsx
08-13-2015 08:28 PM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
