97 Z71 going for 13s, advice needed(vid inside)
Old 10-12-2009, 03:38 PM
james8997's Avatar
Default 97 Z71 going for 13s, advice needed(vid inside)
hello to everyone, im a noob here, my name is James.
i have a 1997 K1500 ext cab, i used to take her muddin, but those days are done. i recently rebuilt the L31 350, added some goodies(see vid) im workin on my PH.D in jackassery if you cant tell, anyways, im workin on turn my truck into a 13 second street truck. i know i should find a newer, lighter truck to do this with, but thats to easy lol. future plans are to lower it, and throw some smaller tires on her. gears are a must, im runnin 3.42s on 33 inch mud tires and its killin my off the line performence, im thinkin some 4.30s. after that, a 2800 stall converter and a 100 shot of nitrous. do yall think thats enough to get me into the 13 second 1/4??
heres the build vid...
http://www.youtube.com/watch?v=p708l3Lvff4
(after 3:00, turn it off)
thanks for all advice
BTW, tuning was done by Wheatley performence tuning, he does great work and is a great guy to work with
Old 10-12-2009, 04:19 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Welcome to PT.net
Gears and converter with smaller tires and a 100 shot might get you close...
Old 10-12-2009, 04:55 PM
james8997's Avatar
you dont think she can run 13s with gears, spray, and a converter??
im also considering a more aggrasive cam, i used the ZZ4 because i intended on using a whipple supercharger, but when it was said and dont, i have to much compression for forced induction.
also a project for the future, a Ramjet intake
Old 10-12-2009, 06:01 PM
outlawz2004's Avatar
With those mods and some weight reduction you may get 13s. One day James, you may get by my lil 4.8 at the track. Didnt get a chance to mess with you about it at the track.LOL. ... And welcome to the site.
Old 10-12-2009, 07:02 PM
james8997's Avatar
whats up elton, yea i was hopin to run ya, but didnt happen, although hunter did have a better time than you lol. when i got home, i started lookin around, one stuck brake caliper, 4 cracked spark plugs, and 5 burnt wires. i knew i felt it missin.
im also considering a more aggrasive cam in the near future
Old 10-12-2009, 08:58 PM
Yeah, I also dealt with sticking calipers. Took off those bullet mufflers the other day and wow, got my power back. I bet Hunter wont beat me next time. I beat him the time before and my truck just wasnt in the game when we went to the track this past time. Once you lower yours, add those mods, and get rid of some of that weight you will be doing good. Your truck runs good, its just heavy and being jacked up it catches a ton of air.
Old 10-12-2009, 09:43 PM
james8997's Avatar
yea im workin on her. still gotta miss, i havent had time to replace the plugs or wires.
idk how much weight shes gonna lose, not much left to take off.
Old 10-12-2009, 10:23 PM
Hitch, tool box, rear bumper, spare tire lift if its still under there. Plus once you get smaller tires that will reduce alot of weight too.
Old 10-13-2009, 07:21 PM
the_husk's Avatar
I bet once you get your miss fixed, your 4.30 gears, and a 2800rpm TC, you'll be closer than you think.
Old 10-14-2009, 01:01 PM
Neil 6.0's Avatar
Location: as far away from Koonerville as humanly possible
Check out this forum for more info geared towards L31 Vortecs:
http://www.pacificp.com/forum/index.php
My name is Neil1500HD over there.
ZONES89RS
21
09-24-2015 05:58 PM
Bluecollar Hotrods
07-16-2015 08:52 PM
Aboss
07-09-2015 10:28 AM
Sbrown06
07-09-2015 09:21 AM
Quick Reply: 97 Z71 going for 13s, advice needed(vid inside)
