98 Vortech cam help
98 Vortech cam help
I have a 1998 Z-71 with a 5.7. I installed a comp cam 206 intake 212 exhaust 110 lobe seperation. I sent my PCM to be reprogrammed because it has no low end power with the new cam. I can't even burn out lol. The programming company sent me back my PCM, I installed and it still has no low end power. He recommended a different cam with a different lobe seperation like 114. I've heard the LT-1 cams work good or what about a hotcam? I'm not interested in putting in a stall converter just wanna find the right cam so I won't have to do it again. If you guys could recommended some that would be great! I would like my truck to rip but at the same time run good. I can always send the PCM back to be reprogrammed with a new cam I just want it to work. Thanks.
thats the trade-off when going w/ a bigger cam. more topend power at the expense of lowend grunt. this is why you need a higher stall converter, to let the motor reach a higher rpm sooner. going w/ a wider LSA grind isnt the answer in my opinion. get a good converter and you'll be surprised how much better itll run. although i am surprised it has made that much difference in your truck, the cam aint that big CHIP
Banned
1 Post
You Have To Be Real Careful With The R Motors We Have Tried All Kinds Of Stuff. Ed Wright Is Best Person To Do Any Kind Of Tunning On This Motor.
We Put A 210/224 Crane Cam In An X-cab With 3.42 Gears And A Stock Converter That Was Turned Upit Would Stall To About 2500 To 2600. It Ran A 14.9,and A Reg Cab With Stock Pcm Running 14.72.
Just Be Carefull Also Ith The Rocker Studs They Are Press In Not Screwed In And With A Big Cam They Can Work There Way Out.
What Else Do You Have Done To The Motor
Originally Posted by vortec350
I highly recommend looking at the Lingenfelter cams,you can see my cam specs in my sig!It is a bad *** cam and made a very nice difference!
You guys might want to look at what Vinci Performance/Crane has to offer. They have a couple of nice looking cams for these motors and a tuner that is calibrated for each of the cams. They are listed as sponsors on the LS1tech.com forum.
10 Second Club
funny you should mention vinci. they did some cam testing in a 98 tahoe 5.7L votec motor last year.
http://www.vincihighperformance.com/...%20PARENT.HTML
