? about 243's
Old 04-08-2010, 09:36 PM
9 Second Club
Rhino79's Avatar
Default ? about 243's
Ok so my lil 4.8 has 243's, what springs and valves do the NNBS truck's version of 243's come with? Are they still the 64cc chamber like the ls6 version?
Old 04-08-2010, 09:40 PM
hirdlej's Avatar
Same casting head, standard valves, springs unknown.
Old 04-08-2010, 09:54 PM
Hunt&Fisherator
silver-mod-o's Avatar
Wrong...09's are GEN IV... Square port stuff. Unsure if chamber size is different.
Old 04-08-2010, 10:11 PM
Dewey's Avatar
why would they have the same casting number if they were different
Old 04-08-2010, 10:37 PM
caddy03pimpin's Avatar
No he is correct... 243 are 243.. There is no difference in them or they would have different casting numbers
Old 04-08-2010, 10:41 PM
9 Second Club
Rhino79's Avatar
Do they have the LS6 springs??
Old 04-08-2010, 10:56 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Pull the oil filler tube and you can see the springs easy, if theyre yellow youve got the LS6 springs.
Old 04-08-2010, 10:59 PM
9 Second Club
Rhino79's Avatar
From what I've found online, the only difference between them and the LS6 vette heads are that the valve seat material was changed for higher mileage durability and and the valves are standard valves not the sodium filled version, and supposedly they have the LS6 springs.
Old 04-08-2010, 11:12 PM
9 Second Club
Rhino79's Avatar
Popped the oil fill tube out, springs are not yellow, may call the dealer tomorrow and get the part# for them and try to cross reference them.
Old 04-09-2010, 12:15 AM
Banned
max1's Avatar
243/799/ ls2/ls6 share the same Combustion chamber ( 64CC) valves are 2.00/1.55
the only difference is that the ls6 have sodium filled valves and have ls6 yellow springs.
and they have catheral ports , not rectangle*
zblee
11-11-2015 12:41 AM
tim wellington
09-29-2015 10:17 PM
old motorhead
09-29-2015 08:22 PM
Slammed silverado
09-28-2015 06:14 PM
brandon6.0
09-25-2015 11:58 PM
Quick Reply: ? about 243's
