about to swap in a 6.0(LQ9) + 4L65E in the silverado; quick questions
1. is a crank spacer needed?
2. is anything not interchangeable
3. the crate doesn't have power steering or AC compressor. Can i swap mine on? Alternator?
4. Can I fire it up on 4.8 tuning?
5. anything else I should know?
thanks
trey
thanks
trey
FormerVendor
thanks
trey
thanks
trey
Im not sure on the spacer deal becuase im still running a built 60e. All of your accessories will swap onto the new blockI. ran mine on 4.8 tuning for 2-3 months with no problems. When you first start the motor the PCM may have a hard time learning the new motor, so you may have to keep it running until the idle relearns.
1. is a crank spacer needed? No
2. is anything not interchangeable Not that i'm aware of.
3. the crate doesn't have power steering or AC compressor. Can i swap mine on? Alternator? Should be a bolt on.
4. Can I fire it up on 4.8 tuning? Yes, but it won't run for s**t.
5. anything else I should know? This is kinda a empty question. Who know's what all you know???
thanks
trey
thanks
trey
overall it should be a basic bolt in. what are you going to do for tuning?
well today sucked. slow work. no work ethic.
got most of the electronics out. found a rats nest in my fuse box. driveshafts are out. Radiator is out.
only thing left really is trans/transfercase and fuel lines.
I honestly think going back in will be easier. I dont have to deal with mud/water hardened bolts
