about to swap in a 6.0(LQ9) + 4L65E in the silverado; quick questions
Originally Posted by treyZ28
i'm getting a 6.0 PCM
that may not work well. you need to have a pcm for your truck's setup. if you use a pcm programmed for an awd truck, i don't think it'll work right for a truck with an autotrack transfercase. you certainly can't use one for a truck with a 4L80E. you'd be much better off just having your pcm programmed.
I'm using the AWD transmissions from the 4L65E. Will my transfer case not bolt upto it? Will that not work?
Or should I swap tailshafts and keep running 4x4?
I wont have a problem with the 4.8 TQ converter on the 6.0 flexplate will I?
everything should just be a bolt in. your transfercase and adapter should just bolt right up like it came stock that way. as for the flexplate, you aren't going to need a special one to the best of my knowledge since you're using the 65E.
