ABS recall
Old 09-26-2002 | 07:25 PM
99GMC Can's Avatar
Default ABS recall
The National Highway Traffic Safety Administration issued April 2000
Chevrolet S10/Silverado and GMC Sonoma/Sierra (2000) Anti-lock brakes system motor contains out-of-spec spring clip, which could allow motor bearing to become misaligned; eventually, ABS would be non-functional and DRP system would become inoperative.
Old 09-26-2002 | 07:33 PM
1999stepside's Avatar
Default Re: ABS recall
So if mine went out, and I had to pay for it becuase my warranty was up, do I get reimbursed? If so, that would be good.
Old 09-26-2002 | 07:35 PM
GMC SKI's Avatar
I've had the ABS motor replaced under warrenty what is sounds like is buzzing noise from under the drivers side of the truck
It's a big job and costs alot if you don't have warrenty left 2g's CDN and like 1200 USD
Hope you have warrenty
Jim
Old 09-26-2002 | 07:46 PM
XLR8NSS's Avatar
Adkoonerstrator
I was under the impression that you don't have to pay for recalls whether you have warranty left or not.
John
Old 09-26-2002 | 07:59 PM
IS this just for the 2000 model trucks??
Old 09-26-2002 | 08:09 PM
GREGGO's Avatar
Is it a recall or a TSB? Recalls are free. TSB's are only covered under warranty.
Greg
Old 09-26-2002 | 08:12 PM
GREGGO's Avatar
Nevermind, it's a recall. Here it is.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Recall 00V055000: ABS Motor Spring Clip Defect
Vehicle Description: Light duty pickup trucks equipped with 4-wheel disc brakes. Some of these vehicles have an Antilock Brake System (ABS) motor containing an out-of-specification spring clip. This clip could allow the motor bearing to become misaligned. If misalignment occurs, eventually the ABS would be non-functional. The base brakes would remain fully functional, but the Dynamic Rear Proportioning (DRP) system, which optimizes front to rear brake balance, would become inoperative.
Dealers will replace the brake pressure module valve assembly.
Owner notification began March 27, 2000.
Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact Chevrolet at 1-800-222-1020 or GMC at 1-800-462-8782. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old 09-26-2002 | 08:19 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fast4.8:
<strong>Nevermind, it's a recall. Here it is.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"></strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So if I call those numbers, i should get my money back? Since I had to pay $850 for it.
Old 09-27-2002 | 02:09 AM
Ryan23silverado's Avatar
is that only 2000 models? would they have to bleed the brakes to do this?
Old 09-27-2002 | 07:53 AM
GREGGO's Avatar
Ok here is how it works. The recalls are VIN specific. The one listed above is genneral. If you did not recieve a notice (and you are the original owner) it probably does not affect you.
Here is the recalls for 2000: (it may not affect all 2000's)
NHTSA00V404000 001130 Recall 00V404000: Body Pressure Relief Valve Inoperative
NHTSA00V345000 001027 Recall 00V345000: Possible Brake Line Leak
NHTSA00V222000 000808 Recall 00V222000: Brake Booster Vacuum Hose Kinked
NHTSA00V055000 000225 Recall 00V055000: ABS Motor Spring Clip Defect
NHTSA94V016000 940112 Recall 94V016000: Lower Steering Shaft Defect
Call Chevrolet at 1-800-222-1020 or GMC at 1-800-462-8782. Have you VIN # and they can see if you are affected. These are the ones listed in my ALLDATA. For you guys with different year models, call the # with your VIN and ask them to look it up.
<small>[ September 27, 2002, 07:54 AM: Message edited by: Fast4.8 ]</small>
Quick Reply: ABS recall
